plusnet youview+ remote
jonstannes
Getting +box next few days need another remote for the box will humax DTR T1000 remote work on plusnet box which i believe is a re-branded bt dtr 2100 as far as i can work out? got Hdmi amp 1 input 2 out and ir extender 10m hdmi cable to bedroom tv which worked fine with sky to living tv and bedroom tv and want to do same with the plusnet box
1 REPLY 1
SRB2016
Re: plusnet youview+ remote
Yes, it does and it's a much nicer remote to use too. We kept it as the main remote and use the new one as a spare.
