ipc6023
thehypnootoad
ipc6023
Hi guys getting ipc6023 error only change is moved address all equipment is same the tv comes on for 5 minutes then error comes on till i change channel is there any fix for this thanks
6 REPLIES 6
corringham
Seasoned Pro
Fixes: 7
Re: ipc6023
I believe that is a low bandwidth error - what does a speedtest give for your connection at your new address?
thehypnootoad
Re: ipc6023
57 down 10 upload ive tried reseting box with power down power of and on reset router allowed  Support British Telecom (BT)IGMP Proxying   again
MasterOfReality
Fixes: 57
Re: ipc6023
Hi @thehypnootoad
Sorry to hear this.
Is your TV connected via a LAN connection or over your WiFi?
Thanks,
MoR
 MoR
thehypnootoad
Re: ipc6023
Tried it with ethernet and powerline thanks Ash
EmilyD
Fixes: 111
Re: ipc6023
Hi @thehypnotoad,
Thank you for confirming that you have tried both connecting via ethernet and connecting via powerline adapters. I'm sorry for any inconvenience that the Youview issue has caused. I can see that you have now arranged to cancel your Youview package.
I've also added an update to your broadband fault ticket which you can view here.
 Emily D
thehypnootoad
Re: ipc6023
Hi I have enabled tv again as there's a fault with broadband and a engineer is coming out to hopefully fix this and fingers crossed it will sort the tv out thank you for your help. Ash
