indoor tv aerial?
rkaur
indoor tv aerial?
i currently have a freeview installed tv which works with a indoor aerial. if i sign up for youview would a indoor aerial be suitable as i cant get acess to a external aerial
3 REPLIES 3
agedgopher
All Star
Fixes: 14
Re: indoor tv aerial?
Youview is the ability to record to hard drive the programs broadcast via Freeview. It will therefore be OK as far as the indoor aerial is able to provide signal.
If you are meaning to take the tv service from Plusnet then this does not come via the aerial, but via your broadband connection so will not need any other signal provision.
rkaur
thanks. yes i am taking service from plusnet for sports channels but stil hopefully my aerial is good enough to catch freeview channels. should be because it catches freeview channels on my tv now
adamwalker
Fixes: 128
We recommend an external aerial but as long as the internal one receives all the channels then you shouldn't have a problem.
 Adam Walker
