incorrect aspect ratio
SteveA
Turned on the TV this morning and the image from the Youview box was square and not 16:9.  Changing channels did nothing to affect it. TV was fine on its other sources so it was obviously the Youview box.
I had to power it off and then power it back up... however it took nearly 5 minutes to restart.... which is even longer than normal.
Thought I'd just mention it in case anyone else gets the same problem.
1 REPLY 1
SteveA
Re: incorrect aspect ratio
Did it again this morning.....  Sad
