gold channel 4:3 ratio
REKLAWG
just got plusnet tv added to my subscription and noticed on the gold channel most programmes are in 4:3 this cant be right can it?Huh
7 REPLIES 7
pwatson
Re: gold channel 4:3 ratio
As most of the programmes on Gold were made prior to the mid 90's yes - They were made in 4:3!
REKLAWG
i know that but they're show in 16:9 on sky
Mav
Fixes: 436
I prefer they are displayed as recorded rather than stretched. Can you change the aspect ratio on your TV if that's how you prefer it?
Forum Moderator and Customer
pwatson
Not entirely sure what you mean by they're shown in 16:9 on Sky?  Is the top and bottom of frame cropped off to fill the 16:9 screen or is the picture stretched to fill the width?
REKLAWG
just meant full screen thats how i prefer to watch it, tried all picture settings and cant force it to go full screen.
chenks76
Fixes: 12
Quote from: REKLAWG
no they don't
you have your TV set to stretchy-vision
daro2096
Sometimes the signal to switch from 16:9 to 4:3 doesn't get through the airwaves. I have had the same channel broadcasted a 4:3 made show 16:9 on Freeview and be correctly aportianed on Freesat.
As to OP don't you like the black bars on the left and right of picture?
