can you add a second box yourself?
kcstyle
we have one youview+ box in the living room.
Is it possible to buy another box somewhere yourself and set it up in the kitchen so we can receive and record the extra channels?
7 REPLIES 7
Fixes: 1,291
Re: can you add a second box yourself?
welcome to the forums Smiley
multi-room isn't an option and the internet channels are only available on one device at a time, each time you want to swap the box I believe you'll have to reactive the other box.
kcstyle
ah ok.  thanks for the reply!
No big deal would have just been a nice to have!
cheers!
Kris
Razorback
This was the key factor in my decision to move to BT.
We now have 2 BT Youview boxes on which we can watch internet channels simultaneously using Powerline adapters without any issue and still be able to browse the net comfortably. So technologically it is possible.
I suspect PlusNet will get there in time
w23
Fixes: 4
Does BT charge extra for this facility?
Call me 'w23'
Fixes: 1,291
yes.. it's £5 per month.
HairyMcbiker
Fixes: 21
I seems like you need Entertainment + to have multiroom but no mention of the cost on the public pages anyway.
Razorback
You also get the ability to watch the internet channels anywhere (in UK) using the BT app
