Youview on more than one TV
bernardwright
Is it possible to have youview on more than one TV in the house? I have it on the main one but would like to be able to use it when in the home office. Thanks.
2 REPLIES 2
Fixes: 1,291
Re: Youview on more than one TV
You can't have the ip channels set up on more than one device,
bernardwright
Thanks - ok so there is no way to have it viewable on more than one TV per box? Think I will look at plan B then.
