Youview boxes
rob22
Youview boxes
Hi Everyone,
Does anyone know if I can use a Youview+ box in one room and a Youview box in another? Want to replace Sky as too expensive. Also, is E4 channel available on Plusnet tv? Thanks.
3 REPLIES 3
Fixes: 1,285
Re: Youview boxes
You can only use the IPTV channels on one box, there's no multiroom.
E4 is on freeview, so is available
rob22
Re: Youview boxes
Thanks for the prompt reply, another channel question - is TLC channel an IPTV channel?  My wife watches it quite often in both rooms. Thanks.
Fixes: 1,285
Re: Youview boxes
Yep, it comes as part of the base package.
