Youview box
bazinga_81
Youview box
Which box do you get (make/model) with the tv if choose recordable one? Just already have a youview box and not fussed about the ability to record extra channels so wondering if it's worth getting it and paying the £50 for a newer box or best to just go with non recordable box and use my old box instead so can record freeview channels
4 REPLIES 4
Fixes: 1,291
Re: Youview box
pretty sure it's DTR-T2110 500GB
biggles001
Re: Youview box
Yes Dvorak,you're right,a very neat little box,and (tempting providence !) reliable.Had mine since last November,with only a couple of minor problems,which were solved by a technical reboot,no complaints!!
bazinga_81
Re: Youview box
Thanks had a look and going go for that worth the £50 for the box one i have got is the very first recordable one talktalk gave out.
biggles001
Re: Youview box
Hi bazinga_81,I would call PN first and possibly save 50 notes by trying to negotiate a free box,but that might involve a new contract.My old Talktalk box,a 372 is still going strong,but has a 320gb hard drive,and is only used a normal PVR,without IPTV access.
