Youview box trouble
Bamboozled
Fixes: 4
Youview box trouble
Hi
Box came up with "Update available" this morning so I ran it but now its stuck in cycle of trying to restart
I have tried turning on / off as that is all I know. Currently leaving it off for 30 minutes
Ive read about Resetting the box but cant find how to do that. Know theres help using Box but cant get to it !
Any help gratefully received Thanks bamboozled
17 REPLIES 17
Bogbody
Fixes: 4
Re: Youview box trouble
Bamboozled
Fixes: 4
Thanks for reply
I will have to try a reset of some kind because I have noticed that Box goes through cycle Waking up Please wait Loading then the Blue light goes off - and goes Red - so presumably switches itself off
Then Blue light comes back and cycle starts again
Bogbody
Fixes: 4
How old is the youview box and exactly which model?
For example - does the mains lead go straight to the box or is an external supply plugged in?
If a reset does not fix it, a hardware failure (the hard drive?) may have occured.
Bamboozled
Fixes: 4
Hi and thanks for reply
Guess Box may be 4 to 5 years old - time flies may be more lol
Model is DTR-T2120/500G/plusnet
Box plugged in to socket using a transformed plug ?
At least I now know Model No. if i need to do reset lol
bamboozled
Bamboozled
Fixes: 4
One further Q in case you can help
I was looking to see how to reset 2120 but its in its cycle so I dont seem to be able to get to any menus or break its cycle
However following intructions does not seem to work either. I turn box off then on and red light appears - but - pressing downshift button (above Back button) does not turn light on/blue so I cant get to Maintenance Menu to reset ?
Am I doing it wrong pls
Bogbody
Fixes: 4
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
You will need to go in via Maintenance Mode.
Note read ALL the linked page as you could loose all your recordings.
The method varies from model to model.
Again, you could loose ALL your recodings.
Bamboozled
Fixes: 4
hi i dont mind losing recordings - dont have anything i really want to keep
however turning switch off and trying to turn on with remote down arrow wont work
did find a 2120 reset instruction on here which says hold down arrow on set top box [with power off] - then turn power on
hold down button till maint menu appears ar bottom of screen [i can see that now]
but when i then let down arrow go and press Power i get no further
Sorry i may be stupid but am i mssing something out - as box just goes into cycle routine again
cheers bamboozled [i chose name or a reason lol]
Bogbody
Fixes: 4
Ok, best I can suggest is to switch it off at the mains and leave it for a few hours.
Try it then.
If that fails disconect the internal hard drive and try again.
Google for instructions - its not difficult to get at.
If it works without a hard drive connected thats a big hint 🙂
Fixes: 1,138
Welcome back @Bamboozled Smiley
Sorry for the issues with your set top box. Let us know how it goes, if you continue to have problems we can send you a new box as it'll look like your one's on its way out.
Bamboozled
Fixes: 4
Hi Gandalf
Thanks for the message - you probably read earlier Box asked me to allow update this morning after which it does a Boot up cycle then it finishes by turning itself off and then straight back on
I have tried all suggestions and nothing has worked. Just left it off for 3 hours ish but made no difference. Problem is I am looking for a way to reset it [not got anything vital recorded]
I can get message across bottom that leads to Maintenance but it says Y=Power and when I press the Power button nothing happens
Am I dong something wrong pls or is there a different way ?
cheers bamboozled - but it doesnt take much lol
Fixes: 1,138
Thanks for getting back to me @Bamboozled
Can you confirm you've tried the following steps?
Make sure your box is connected to the internet
Open the Main Menu
Select Settings*
From Information & reset select Factory reset
Select Reset
Enter the numbers you see on screen to confirm you want to reset your box
Your box will now reset itself and we’ll walk you through the setup again
Bamboozled
Fixes: 4
No have not done it like that - I cant because I cant find a way to break the cycle of it booting up
It gets as far as Loading ...thenscreen goes black - then light goes Red - then back to 1 Blue one and so on
cheers bb
Fixes: 1,138
Ah OK. I've arranged to send you a new box you should receive via courier within the next couple of days. We'll send you an email with a tracking reference on it shortly. Let us know how it goes once you've got it.
Bamboozled
Fixes: 4
Many thanks
Sorry for late reply needed a walk lol
thanks again bamboozled
