Youview box going to sleep
firecloud
I am having to reboot my Youview box every 2 weeks after it goes to `sleep`.
I have it set on Smart energy saver and will only come to life afer rebooting.
Has anyone similar problems.
3 REPLIES 3
jafreer
Re: Youview box going to sleep
I have the YV+ box and have never experienced this. The only thing that happens is that after 12 hours of inactivity, it goes to standby. I think it will still record etc and I have it set to recover from standby quickly.
The 2 week thing you refer to, I have never seen that.
Interceptor121
Fixes: 5
There are similar situations resolved with a software update
Try booting in maintenance mode with software download without deleting the recordings
firecloud
No amount of software updates or maintenance reboots helped.
Finally solved by a replacement box from an engineer visit.
