Youview and mikrotik router
- TV
- Youview and mikrotik router
15-09-2015 6:21 PM
Hello hopefully this can be a quick fix. I’ve just got myself bt sport with the youview box but having issues when trying to watch the channel, I’ve currently got a mikrotik router so setting it up is quite a challenge and was hoping someone knew what to do.
Message 1 of 7
(1,801 Views)
6 REPLIES 6
Re: Youview and mikrotik router
15-09-2015 7:04 PM
It not looking promising, have a look here for Routers that work with multicast https://community.bt.com/t5/YouView-Boxes/Known-Routers-to-Work-with-Multicast-IGMP/td-p/994338
Message 2 of 7
(673 Views)
15-09-2015 7:20 PM
That link is out of date since my Netgear d7000 works as well as the billion 8800axl.
Fibre Broadband 80/20, Netgear D7000
Message 3 of 7
(673 Views)
15-09-2015 9:02 PM
the mikrotik router you can do quite a lot of things with so i do have hop. i keep finding stuff about iptv and the setups but just keep going around in circles
Message 4 of 7
(673 Views)
15-09-2015 9:05 PM
Is there a dedicated forum for your make of router? Plus If they don't help - I highly recommend you post in these 2 forums for help: http://forum.kitz.co.uk/index.php/board,5.0.html and http://forums.overclockers.co.uk/forumdisplay.php?f=6
People on these 2 forums are super helpful and knowledgable and one of the forum users put me in touch with a Netgear guy who (after much tinkering with test firmware) finally figured out how to enable my router for IPTV.
Good luck!
Rick.
Good luck!
Rick.
Message 5 of 7
(673 Views)
15-09-2015 9:57 PM
ok thank you for your reply
Message 6 of 7
(673 Views)
17-09-2015 1:55 PM
If you do/did get this working, it would be useful if you could add what you did to this thread: http://community.plus.net/forum/index.php/topic,124042.0.html so people can see it in the main multicast config thread
Message 7 of 7
(673 Views)
