Youview Remote code
- TV
- Youview Remote code
Youview Remote code
13-09-2016 1:48 PM - edited 13-09-2016 1:49 PM
Just got our box today and trying get remote control work on tv aswell the code plusnet says doesn't work and all ones found on net for bush tv don't work either on off chance has anyone got a
bush 40/233f 40 inch tv
And have code for it?
Message 1 of 4
(787 Views)
3 REPLIES 3
Re: Youview Remote code
12-10-2016 12:18 PM
Hi @bazinga_81,
Thank you for getting in touch wit5h us regarding this query. If you are still needing the codes to link the remote to your TV then below is a list of codes for Bush TV's to link up.
102, 006, 144, 134, 204, 138, 087, 061, 043, 036,
005, 108, 376, 373, 370, 361, 355, 352, 327, 388,
430, 431, 432, 440, 448, 451, 473, 476, 477, 478,
002, 033, 035, 044, 045, 056, 059, 065, 066, 095,
133, 164, 210, 213, 229, 232, 250
Message 2 of 4
(725 Views)
12-10-2016 12:26 PM
@BenB
It need's 4 digit code not 3 digit ones and i tried all the 4 digit ones i found on pn site and rest of internet and none worked
Message 3 of 4
(719 Views)
12-10-2016 12:49 PM
OK and was it the 0746 code you used with your Bush TV?
Message 4 of 4
(711 Views)
