Youview Box
firecloud
Youview Box
Is anyone having the same problems with their Plusnet Youview box.
Mine is now daily requiring a software re-set before I can use it.
I have used every available maintenance routine to try and get it to work.
I have tried factory re-set, software re-tune etc. Still requires a reboot to get it to work.
Presently set to Smart and was told by Support to change to Eco but that made it worse.
I have now set it to Always on to see if that solves it.
2 REPLIES 2
BenB
Fixes: 20
Re: Youview Box
Hi @firecloud
Thank you for getting in contact with us regarding this. Are you still experiencing the same issues with the software?
firecloud
Re: Youview Box
Problem solved by a replacement box.
Thanks for teply
