YouView Box and HDCP compatible HDMI switches
pnetmaikel
Hi guys
today I received my new youview T2220 set top box.
The setup was easy but when I connected it to my 4x2 HDMI switch I noticed that the switch is not able to handle properly the HDCP handshake and an error message appeared on the screen.
Can anybody recommend a HDMI switch compatible with the you view box? Btw: It's the simple one without the recorder.
1 REPLY 1
ricke17
Re: YouView Box and HDCP compatible HDMI switches
I highly reccomend this one which I use with my pn youview box, apple tv etc.
It has a remote which you use to choose the input and is available with 3 or 5 (I got the 5 port one).
3 port: http://www.amazon.co.uk/gp/product/B0049S6ZUS?keywords=hdmi%20switch&qid=1440562964&ref_=sr_1_6&sr=8...
5 port: http://www.amazon.co.uk/gp/product/B0049SCB2Y?keywords=hdmi%20switch&qid=1440562964&ref_=sr_1_4&sr=8...
It is pricey but worth it IMHO.
Rick.
Fibre Broadband 80/20, Netgear D7000
