You View Remote
You View Remote
I have followed the instructions on how to set up the remote to control the tv. At Step 3 it turns the TV off but will not turn it on again. I have tried the OK trick but that does not work either. The BT remote works perfectly OK but of course will not acivate My TV. The You View remote controls the You View Box .Is it a fault in the You View remote?
10 REPLIES 10
Fixes: 126
Re: You View Remote
Hi there, results using the YouView remote to control a TV can vary depending on the TV being used. Is the remote working OK in terms of powering the YouView box on and off etc?
 Adam Walker
Re: You View Remote
The remote controls the You View box but will not connect to the TV
Fixes: 126
Re: You View Remote
Can you let us know the make and model of the TV please and I'll do some digging and see what I can find out.
 Adam Walker
Re: You View Remote
The TV is a Panasonic TX-L26C10B. My BT remote controls the TV and the You View box but will not connect to My TV.
Fixes: 43
Re: You View Remote
Hi @gws20,
We can send you another remote to see if it is going to make a difference although it is unlikely to be an issue with the remote.
It could just be that the remote does not work well the the brand of TV you have which I am afraid we cannot help with.
 Faris
Re: You View Remote
The BT remote looks identical to the You View and that I set up without a problem. Seems strange that the Plusnet version does not. I am not sure a replacement one will be any better but we can try. I will return it if there is no joy.
Fixes: 43
Re: You View Remote
I have created a ticket on your account @gws20.
Please click here to view my response.
 Faris
Re: You View Remote
The new remote has arrived but will not control the TV either. After pressing TV and TV AV I get the three blinks but the blue light remains on.
As the result is the same I will return the remote if you can give me the return address.
Fixes: 163
Re: You View Remote
Returns details here.
Regarding the issue you're experiencing, I take from your replies that you've read this? - https://community.youview.com/youview/discussion/6029547/controlling-panasonic-tv-with-bt-youview-re...
Re: You View Remote
Thanks bobpullen I had not seen that thread. Took the battery out after switching off step and remote works. Thanks for the help all.
