YV Box remote
Mayfly
Seasoned Pro
YV Box remote
The box and the remote don't appear to be communicating as they should.
New batteries and I've re programmed it but it's take 4-5 presses to get the box to respond mainly seems to be 'My TV' & recordings. I've always had a problem with it communicating with the TV as in I have to switch the TV off and on again after making sure the TV is on the external channel for the box.
Anything else I can try?
1 REPLY 1
RandallFlagg
Fixes: 75
Re: YV Box remote
Hi @Mayfly
Thanks for getting in touch.
One thing you can try is to reset the remote. You can achieve this by following the instructions below:
· Hold down the Audio Description , Delete/SUB  and MyView  buttons at the same until the blue light at the top of remote flashes three times
· Release the buttons
Let us know how you get on.
Best wishes
Dave
