Will youview+ box work after 1st Nov
TonyA
Help!!!
I intend moving to BT in the next 30days but have a load of saved programmes on the youview+ box. Will I still be able to watch them ?
Hope someone can help
2 REPLIES 2
mrmitch85
Re: Will youview+ box work after 1st Nov
I think it depends.
It will continue to work as a Freeview box / recorder .... So if you have taped any programmes from Freeview then you'll still be able to watch them.
If you have taped anything from the additional channels (i.e the ones numbered from 300+ that you pay for) then my understanding is that you won't be able to watch those back after the 1st of Nov.
Cww45
Hi. As I understand it. If the recordings are from normal freeview channels then they will play back ok. Anything recorded from the additional tv package you paid for like BT Sport won’t be playable.
Edit. I just thought. If you’d moving to BT sport the ip adresses in fact most of the service is exactly like PN so you might be lucky.
