What Are My Options For A 2nd Or Even 3rd Box?
PembsPanther
Afternoon Smiley
As the title say really, already have the Youview + HD pack through PN, love it, it is a great thing but would like to add some more boxes 2 maybe even 3 depending on price, how can I do this with PN?
Thanks in advance
15 REPLIES 15
chenks76
Fixes: 12
Re: What Are My Options For A 2nd Or Even 3rd Box?
i don't believe plusnet offer a multiroom option.
MatthewWheeler
Fixes: 405
We don't offer this at the moment I'm afraid.
 Matthew Wheeler
PembsPanther
Sad
Is there any way I could just pay the same cost x 3, essentially 3 separate packages or is it more technically not possible yet?
npr
Fixes: 8
I don't know if it's possible, but I'm tempted to buy a cheap youview box from ebay and give it a go. Cheesy
HairyMcbiker
Fixes: 21
It's been tried. What happens is only ONE box will work the rest get no channels. (internet ones)
npr
Fixes: 8
Do you know if that was using a BT router or a more competent router.
HairyMcbiker
Fixes: 21
ANY router, I use a TP-link one.
PN haven't enabled multi-room so the only one box can be enabled.
What usually happens is the wrong box is active when you want to watch something, and it is a PITA to change (switch off all boxes, switch on master, get internet channels working (hopefully), then switch on 2nd box and don't select an internet channel)
Gel
Aspiring Champion
Fixes: 25
Browni
Aspiring Hero
Fixes: 52
You can get one from Argos for £15.
Ex-Plusnetter now living life in the G,fast lane!
biggles001
I use an old TT box as my second one,and catchup tv and the different players all work,as per Youview specs
racey
Are there any plans to introduce multi-room?
HarryB
Fixes: 255
No plans for it at the moment unfortunately.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
sarczoid
NowTV allows four devices at once Smiley
Gel
Aspiring Champion
Fixes: 25
4 devices can be registered {on NOWTV} but you can only watch on 2 at any one time.
(Per NOWTV WWW)
Yes, you can connect as many NOW TV Boxes as you like within your home. Just remember that you can’t watch NOW TV on more than two devices at the same time.
