Using the BTTV app for remote recording
bobpullen
Fixes: 174
Background
As some will be aware, YouView discontinued their native mobile app at the end of March.
To preserve the remote recording functionality, some modifications were made to the BTTV app so it now allows non-BT YouView customers (Plusnet included) to use it.
Configuration
Here's how to set-up and use the app on an Android phone (instruction for an iPhone will be similar, however the menus etc. may look a little different):-
  1. Download the BTTV app from the App Store (iOS) or Play Store (Android).
  2. Once installed, open the app and click the 'hamburger' menu top-left (three horizontal lines) to open the overflow menu.
  3. Tap 'Settings'.
  4. Under 'TV box' you can see the pairing status. Tap the arrow to the right to start the pairing process.
  5. Make sure your YouView box is powered up and you have your TV remote to hand. You should also ensure your smartphone is connected to the same network as the YouView box. Once ready, tap 'Next'.
  6. The app will search for youYouView box (could take a minute or two).
  7. Tap 'Next' once the app locates your box.
  8. Accept the prompt from the YouView box using your TV remote.
  9. Success!
  10. To remote record a scheduled broadcast, navigate to the 'Live TV' section of the app and ensure 'Full TV Listings' is selected.
  11. Either locate the program in the programming guide, or click the magnifying glass top-right to search for a program. Make sure you have 'On Now & Later' selected.
  12. Select the broadcast you are wanting to record and choose the relevant option to send the request to your YouView box. Please note it can take a short while for the recording to show on your set-top box.
  13. To view a list of your current recordings, or to see what you have scheduled, navigate to the 'My TV' section of the app, and tap 'Recordings List'.
FAQ/Known Issues
Q. Why am I being prompted for a username password?
A. The app caters for additional BT content/features that are not available to non-BT customers, which includes Plusnet. If you attempt to access an area of the app that is specific to BT subscribers, then you will be prompted for a BT account username name and password.
Q. The app says my username and password are incorrect?
A. See the question above. The app is prompting for a *BT* account username and password, not a Plusnet One. Unless you have an active BT account with an active BTTV subscription then you will not be able to log into the app.
Q. Some of my channels are missing from the EPG/Programming guide?
A. This is a known issue that is currently being looked into. For further explanation, see the post here.
12 REPLIES 12
GaryB1
Re: Using the BTTV app for remote recording
I downloaded the BT TV app but it won’t let me connect to my Humax DTR-T2120 box, it keeps giving the error code Ay182 which “allegedly” means the software is out of date BUT my software IS the latest available.
This is on both my iPhone SE and iPad Air 1st gen.
Tags (1)
bobpullen
Fixes: 174
@GaryB1 it seems you're not alone. There's an imminent update due that should resolve this. If you're still experiencing issues after your app updates then let me know.
I can't see the update yet, despite 24hrs having passed since that post ^
Hopefully it's not too far around the corner though.
GaryB1
Many Thanks for the quick reply Bob, people have also mentioned that the app doesn’t show their actual channels list, also I’ve not that certain of the Plusnet extra tv channels are missing, I have the entertainment and BT sport lite package but can’t see Eurosport 1 + 2 and about 10 other channels. With luck that’ll also be sorted.
Thanks again mate.
Tags (1)
GaryB1
The BT app is finally working for my iPhone SE and iPad Air first gen, thanks to all those that helped work through the problem.
Tags (1)
Taylor09
Still no Eurosport in the TV listings though.
bobpullen
Fixes: 174
@Taylor09, that's being looked into as per my post here.
Again - no guarantees - but we're looking to see if it's possible to inherit the EPG listing from the set top box pairing instead. Even if possible, it will require an app update so won't be a quick turnaround I'm afraid.
I wouldn't expect to see much movement this month.
83DF
I have successfully paired my Plusnet supplied Humax DTR-T2120 with the BT TV App but I am only able to set recordings directly from the box itself using the remote. Any recordings I try to set from the app do not show up in the “My Recordings” list (just says request sent). I have tried unpairing & re-pairing the box. Any ideas?
fishyweb
Is there any update on the missing Eurosport listings?
It's been several months now and, with the resumption of the pro cycling season, I could really do with being able to set recordings on Eurosport! Hoping for some good news on this...
ChrisBithell
Subscription channels do not work functionality is rubbish not fit for purpose whoever decided to get rid of the you view app should be shot
In the past I have actually forgot to record things whilst on holiday in Greece I have set up recordings and caught the programe I wanted now I would be left high and dry if I wanted to set up a recording on a subscribed channel e.g. Comedy Central
p'd off
bobpullen
Fixes: 174
I'm afraid not, we hit a pretty big barrier with the intended solution in that recording requests for the missing channels wouldn't work (once we made them visible).
I need to find out where we got to with things, but I've a feeling we may have hit a bit of a brick wall Sad
fishyweb
Thanks for the update Bob. I have to say that's a very disappointing situation. If you're able to pull the right levers to get alternate solutions explored, it would be much appreciated, and might entice me to stay with PNTV.
Taylor09
Is there no option to reuse the YouView app or at least the underlying code it was built on?
