Using existing BT Ultra HD 'DTR-T4000' youview box
staley84
I have been using a BT Ultra HD 'DTR-T4000' box as a regular youview recorder for some 18 + months. It's a great device, fast and has 1TB disk.
Is it possible to use this box on the Plusnet TV service? Section 9 of https://www.plus.net/tv/faq/ suggests not, but i've read otherwise on the forums.
I don't want a new box as his has many recording on it that i want to keep.
Thanks.
2 REPLIES 2
Slickric211
Re: Using existing BT Ultra HD 'DTR-T4000' youview box
That’s exactly what I’m using and works fine. My Plusnet T2220 is still in its wrapper.
The BT UHD box worked straight away and I was able to keep all my recordings.
Note: I’d been using it as a standard YouView box for a while before activating Plusnet TV last week.
staley84
