Use BTTV Youview box on Plusnet
rawhoe
Can I use my BTTV Youview box on Plusnet?
Thanks for any answers.
6 REPLIES 6
Fixes: 1,148
Re: Use BTTV Youview box on Plusnet
Hi there.
I believe you can, I've seen threads around here about people making it work with our YouView service.
Though, it's not something we'd be able to support you with or guarantee it would work.
wisty
Fixes: 8
I would think so. I went the other way PlusNet to BT.
I did a Factory reset (Keeping Recordings) on the PlusNet YouView box once the BT broadband was up and running. I then got BT branded TV and the channels they provide with no problems.
rawhoe
Thanks for your helpful response. Do you know if anyone has been able to put BT Sport on a BTTV youview box just the same as a Plusnet box. I do have the BT version on now but that would be replaced by the Plusnet version.
I understand that it would be unsupported.
rawhoe
Thanks for your help.
beeceegee
I have all the PNTV channels, including BTSport and HD channels on a BT Youview box I got off ebay. My PN Youview box is still in its box. As has been suggested above, you may need to do a Maintenance Reset (keeping recordings), but I don't recall having to do one myself (apart from when the box hung completely one time)
rawhoe
Thanks good info
