Unable to get bbc and itv on my YouView tv
Bradleylauren
I have recently set up my YouView tv and did a channel scan. I have channels however not the usual, bbc, ITV, and channel 4. Am I doing something wrong?
2 REPLIES 2
DS
Champion
Fixes: 22
Re: Unable to get bbc and itv on my YouView tv
Welcome to the forums @Bradleylauren
It's been a while, but after setting it up for the first time, once the channels have been found, you should get a prompt to select the region you're in. It sounds like you may have missed this. I think you click on it and any other regions should pop up too.
I too have 2 regions and my box does, for reasons I don't know, want to select the wrong region.
Certainly worth double checking Wink
MatthewWheeler
Fixes: 405
Sorry to hear you're having issues.
From reviewing your account you're only getting the subscription channels that are delivered over the internet and none from your aerial?
If this is the case can you follow through the steps here and let us know how you get on?
 Matthew Wheeler
