TV account settings
apollo1
TV account settings
Hi
I can't see in the account area any options to view my TV packages details i have, is there a direct link?
6 REPLIES 6
Chris
Legend
Fixes: 169
Re: TV account settings
If you log in to the member centre, and then it's in the top menu called 'My Channel Packs'.
apollo1
Thanks Chris
Gerry
I have PlusNet TV but that menu option isn't there.
Can you help.
Cheers
Gerry.
Gerry
I guess that's a no then!
PeeGee
Depends how you login in to the member centre, based on a test. However, if you select "member centre" at the page "tabs" level to go to the member centre home page, "my channel packs" should Undecided appear.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Gerry
My internet channels have gone now. PlusNet don't think I signed up to IPTV. That's the problem.
Cheers.
