TV Remote
skup53
TV Remote
Try As I Might I could not get my new YOUVIEW remote to work/control  my oldish Panasonic TX Viera TV.
So I searched the blogs and forums to no avail. I identified it as a HUMAX but none of the codes worked.
As a retired IT manager I am fairly confident with Technology.
BRAINWAVE    I had a go at configuring the remote  in another room, where i have a more modern Panasonic TV.
This process worked fine with the standard panasonic code 3846. Worked first time, then walked into the other room where the old Panasonic TV is and the youview remote worked straight away.
1 REPLY 1
adamwalker
Fixes: 128
Re: TV Remote
Thanks for posting, that's likely to help someone else looking to do the same thing.
 Adam Walker
