TV Problems / Picture freezes at times / all programs
sashajezebel
For the last few month, my tv-pictures on all channels freezes at times-I don't know why-wonder if it has happened to anyone else
13 REPLIES 13
Mayfly
Seasoned Pro
Re: TV Problems / Picture freezes at times / all programs
I get pixalation and break up on some of PNs internet channels. Still trying to find out why.
Daniel28012
@sashajezebel have you tried a maintenance mode reset?
sashajezebel
Hi, Daniel-thank you for your tip! How do I do that-sorry for my stupid question
Fixes: 215
Is it freezing on live TV or stuff being pulled off the internet? It could be that your data rate is too low. How are you connecting to your router and how fast is your connection?
TheMightyAJ
Fixes: 85
Hi @sashajezebel,
If you'd like to carry out a maintenance mode reset on your YouView box, please refer to the relevant guide on the official YouView support site which can be found here.
Hi @Mayfly,
Do you experience the same issue when streaming to other devices or is it only when streaming to your YouView box?
 Alex H
sashajezebel
Thank you!!
Mayfly
Seasoned Pro
@TheMightyAJ I've only noticed it when using the TV. However I'm having the master socket moved so will see how it goes once that's done.
OskarPapa
Fixes: 64
Hi @Mayfly, thanks for your response.
Are the issues experienced when using Freeview channels, or internet based subscriptions such as Netflix, Amazon Prime Video and the like?
I'm asking as if it's also affecting those internet subscriptions we can discount the aerial being at fault here.
Do other TV's in your property have the same issue?
Mayfly
Seasoned Pro
@OskarPapa sorry only just seen your response. So far I've only seen it on Nat Geo, Nat Geo Wild and Universal so only the one TV, (we had our aerial updated a few years ago) but in fairness I haven't watched many other PN channels as yet.
MatthewWheeler
Fixes: 405
Thanks for the information.
Can you confirm if the YouView box is connected directly to the router or through PowerLine extenders?
 Matthew Wheeler
Mayfly
Seasoned Pro
@MatthewWheeler if you are asking me it's through PLA hence the reason I'm having the master socket moved.
MatthewWheeler
Fixes: 405
@Mayfly Sorry the response was indeed meant for yourself
Will you connect the YouView box directly to the router once the master socket is moved?
It'll be interesting to see if the issue persists
 Matthew Wheeler
Mayfly
Seasoned Pro
Yep,  that's the idea.
Will let you know if there is a difference.
