TV Error code not listed.
ashleysprigg
Hi guys.
I got my youview box 2 days ago and set it up to both antenna and router.
Getting error BTW-20000 call plusnet.
I can't find it in the error code list and no luck searching the TV forums.
Any ideas what this error code is?
I'm just guessing my service is not setup yet.
2 REPLIES 2
mikelahey
Fixes: 12
Re: TV Error code not listed.
What router are you using, are you using a Plusnet router or one of your own?
If its one of your own, there is extra config required to get it to work. You need to enable IGMP snooping & IGMP Proxy.
There is also extra config required if its one of the old Thomson Technicolor Plusnet routers.
See: https://community.plus.net/t5/TV/Router-Configuration-for-Internet-Multicast-Channels/td-p/1077600
If its a Plusnet Hub Zero or Plusnet Hub one they come preconfigured this way, so it maybe a different issue.
Fixes: 1,148
Hi there. Apologies for the delayed response on here.
It looks like you've called our support team and spoken to one of my colleagues.
Is your YouView box working now?
