TD-W9970 TV SETUP
ste2112701
TD-W9970 TV SETUP
Hi
just ordered plusnet tv could anyone tell me the setting I need to get this to work with my tp-link w9970
I have Enabled IGMP is there any other setting i need to change on the below image link
https://i.imgur.com/M8ShkJI.jpg
thanks
4 REPLIES 4
mharvo
Re: TD-W9970 TV SETUP
You need to input VLAN ID as 101 as the picture you have posted shows 1 !
my Asus DSL-AC88U works this way
and need to connect to LAN Port 3 from router to the youview box
ste2112701
thanks will give that a go when I recive box probably tomorrow
dgilbert2
Did / does this work OK?
dgilbert2
I can now confirm that the TP-Link TD-W9970 works fine with Plusnet TV subscription channels (wired connection).
I have V2 with firmware version:0.9.1 0.2 v0076.0 Build 170919.
It just worked with the default settings as they were, no need to change or enable anything under IPTV as that's a different functionality.
If anyone has issues just check that "IGMP Proxy" is enabled under Network, WAN settings, PPPoE settings, Advanced (tab at bottom of page).
Also check that "IGMP Snooping" is enabled under Network, LAN settings, DHCP Pool in use (usually the "Default").
Smiley
