TCM
demberton
TCM
FOX is gone, but TCM has appeared! This makes me happy.
Are we getting it? It prompts me to set it up, but it's not mentioned on the website as part of the channel packs.
4 REPLIES 4
SteveA
Re: TCM
It seems to work... just the SD (unless the HD version is hiding somewhere).
biggles001
Re: TCM
Which channel is TCM on? I don't see it,or have I to do a channel update?
nameloc2080
Re: TCM
I have it on channel 512 in SD. Included in the Entertainment Plus package.
dick:quote
biggles001
Re: TCM
Thankyou for your help,found the answer to my question by checking the channel listings myself!
