Syfy Channel - Logo Issue
s1m0nh
I know it's a minor issue, but part of the S in the Syfy onscreen logo is off the screen. It might be an issue with my TV but I doubt it as all other channels are fine.
Is it just me or can others see this? If so, can anything be done by Plusnet?
3 REPLIES 3
PeterLoftus
Re: Syfy Channel - Logo Issue
Yes it is. In fact it's right on the edge when you change the aspect.
I can live with it, I doubt Plusnet will have any control over it it's as mastered  Wink
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
s1m0nh
Hopefully Plusnet will at least investigate. But like you, I can live with it.
auto98
Plusnet Staff
Plusnet Staff
It is kind of TV related - if you go into your TV settings and change the aspect ratio, you'll find it fits properly on some of the settings, in Auto mine doesn't show it properly either, I either have to specifically set it to 16:9 or overscan, depending which TV it is.
