Subscription Channels Pixelation
dgilbert2
I have started to get pixelation on all my Subscription channels which at times is almost unwatchable. Seems to be mainly early evening.
I have reset the Youview box and router but this did not help.
I am not seeing high errors on my line from this end.
Any thoughts please on how to fix this?
3 REPLIES 3
adamwalker
Fixes: 128
Re: Subscription Channels Pixelation
Everything looks fine according to line diagnostics.
Able to try another ethernet cable?
 Adam Walker
dgilbert2
Thank you for checking my line. I cleaned and reconnected the Ethernet cable plugs and things were good tonight. Will see how it goes over the weekend, fingers crossed Smiley
kevdwyer
Might be worth double checking that the HDMI cable is firmly seated. I had this with my YouView box, I reset the router / pulled out and reconnected the RJ45 leads etc. Then I noticed that the HDMI cable was slightly adrift, probably happened when I pulled the box forward to straighten it up.
