Strange issue this morning (fix included)
HairyMcbiker
Fixes: 21
On switch on, all we had were the INTERNET channels, you could move through the guide but it scrolled back to the start of the IPTV channels when it got to the end of them.
Pressing a channel button just gave no channel.
So all the terrestrial channels were missing. (100+)
(FIX) A rescan brought them all back and KEPT the hidden ones as well, which it normally doesn't.
2 REPLIES 2
Minivanman
Aspiring Legend
Re: Strange issue this morning (fix included)
We only have freeview terrestrial channels on ours but quite often, half are missing from the menu when the set is first turned on and it take a minute or so before they all appear. I've put it down to getting a weaker signal from the much lower powered relay transmitter we pick up from nearby - we have lot's of 'em in Wales and it's either that, or those chipsets are running slow!
Maybe the motherboard needs dusting. Wink
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
HairyMcbiker
Fixes: 21
My problem was the OPPOSITE.
I had NO terrestrial channels. I only had the few IPTV channels.
The rest were listed but unselectable.
