Sound problem
ebostgriff
Sound problem
When I decide not to continue watching a programme and bring up the guide, the programme sound continues while the guide is displayed.
Apart from muting, is there any way I can stop this happening?
7 REPLIES 7
Interceptor121
Fixes: 5
Re: Sound problem
Essentially you want to switch the guide without the screen previews however this is not possible
ebostgriff
Re: Sound problem
Thanks.
Looks as if I'll have to carry on muting!
Interceptor121
Fixes: 5
Re: Sound problem
Actually am wrong
In the accessibility menu there is an option Mini Tv -->off
Try it
ebostgriff
Re: Sound problem
Yes, I had found that, thanks.
The mini screen goes, but the sound stays.
Interceptor121
Fixes: 5
Re: Sound problem
Yes it is not like the sky epg
BenB
Fixes: 20
Re: Sound problem
Hi @ebostgriff
As @Interceptor121 has mentioned, the sound will continue when going on to the guide screen even with the mini screen disabled.
ebostgriff
Re: Sound problem
So I've discovered!
The mute button will wear out quickly.
