Sound out by a little bit!
stef1989
Anyone having issues with the speach about half a second slower than the picture?
It's getting really annoying now and it's even worse on the "internet" channels. I've made sure the box is up to date etc and all the settings are correct on the box and tv. At first i thought it was the tv, but i tried another one and that's the exact same.
1 REPLY 1
jafreer
Re: Sound out by a little bit!
Can't say I have ever noticed an issue.
If you go into the 'TV Signal & Quality' menu, there is an option called 'Synchronise Picture and Sound'. I haven't messed around with it but I suspect if you adjust this you may be able to resolve your issue.
