Sony Movies +1 on Youview box
rob22
I can get this channel fine on my Freeview Sky box in the other room, but on the Youview Plusnet box in the main room, when I go to Channel 60, it just says " Programmes available from 10pm to 6am " or something similar. Sony Movies channel is received ok on there, so why not the +1 channel too? Anyone any ideas. Thanks.
2 REPLIES 2
Jaggies
Re: Sony Movies +1 on Youview box
I don't have Sony Movies +1 on either of my Freeview TVs or on my YouView box. Channels jump from 59 to 64. I retuned to check.
It may be it's only available in some areas - it does indeed show as channel 60 on the Freeview web site - https://www.freeview.co.uk/get-freeview-play/channels/sony-movies-1 - perhaps your Sky box gets it's Freeview from a different transmitter?
rob22
Thanks Jaggies, I'll try retuning to see if that makes a difference. I just thought it strange to get Sony Movies ok on Youview, but only Sony Movies +1 between 10pm and 6am on there on Channel 60. I'll try to see if it actually does come on between those times, or its just a standard message displaying because the channel isn't available. at all.
