Sharp tv .you view box connection problems
Alanmac
Just bought new tv sharp lc49cug8462ks
Followed institutions everything  fine set up useing wireless setting
Then went set up you view box
But  on old tv one end of Ethernet cable went into you box then one into tv
But this is already being used on New tv by ethernet cable from adaptor in mains socket
I am not that good with stuff like this so could some help please
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: Sharp tv .you view box connection problems
Sorry, I'm not sure what issues you're having and how this is currently set up?
The YouView box needs an ethernet cable from the router to the box and then a HDMI cable from the YouView box to the TV.
Maloney
Your new tv has inbuilt wifi and does not need an ethernet connection. So ethernet into youview box and hdmi from the box into your new tv and select the appropriate source on remote ie hdmi 1 or 2 etc...
