Series Record failure
SteveA
Anyone else found that the Series Record facility fails for no apparent reason.
Just went to watch the last 2 episodes of a series which I'd set to record, just to find that they're not there
6 REPLIES 6
HairyMcbiker
Fixes: 21
Re: Series Record failure
Yep had that with a couple of series. The solution was to delete the record set and re-set it up.
jjc
I found that if I left the box tuned to a certain channel then the recording failed, no idea why, if I left the box on ITV it always did the recording (recording was on CH5)
SteveA
Quote from: Hairy
Doesn't help when you only find out after the series has finished.
So its another bug in the software.... How do we report these to PN so they can push that back up to Humax?
Mav
Fixes: 436
I have one of the original Freeview boxes from the trials back in 2012 (not PlusNet) and that series record back has popped up several times without a fix Sad
Forum Moderator and Customer
DaveyH
Champion
Fixes: 12
It probably isn't a Youview bug, but the broadcaster ballsing up its CRIDs.
HairyMcbiker
Fixes: 21
That's what I thought, since it only happens on a couple of things, it is unlikely to be a firmware issue and more likely to be the broadcaster, just like the fact the box uses the PUBLISHED start/end times to record, when the program under/overruns then the recording is FUBAR. Since the box is doing what it is meant to it isn't a bug.
