Router for Plus net TV
tolmie35
Hi folks, recently joined plusnet tv after leaving sky, im looking to replace my plusnet router, I know there have been some issues with routers and plusnet tv, does anyone know if the following one is ok.
http://www.amazon.co.uk/dp/B00NEQZ12Y/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=10KF3W8IF9YM9&co...
16 REPLIES 16
thegame2k0
Re: Router for Plus net TV
That will work fine i used it when i was with plusnet.
tolmie35
Did it work with plusnet TV.
Cheers
thegame2k0
Worked perfectly also works fine with BT tv too, it has multicast already enabled so saved me a lot of faffing around when i was with PN.
Very easy to set up too.
Traygar
IPTV compliant - Asus RT-AC87U Router (£160 ish)
For those that want IPTV with Plusnet or BT but want a basic NAS for Kodi in addition and a router that will support gaming and all manner of streaming this router is all singing all dancing beast. I had a Netgear R7000 which worked too with third party  firmware but soon became bricked! This unit has been going strong for a few weeks and IPTV has played back well. Unit has 4 gig ports not the 100mb ones you get the plusnet net free router. I highly recommend though I know its expensive. Good for houses that need strong wifi signals too.
Go to admin settings and change the following settings:
Under Lan go to the IPTV tab and simply enable multicast routing and Enable efficient multicast forwarding
Disable under WAN setting Enable VPN + DHCP Connection select no instead of yes
http://www.amazon.co.uk/ASUS-RT-AC87U-Dual-Band-Gigabit-Wireless/dp/B00NQY3WO8/ref=sr_1_1?ie=UTF8&qi...
fishyweb
The 9980 works a treat. You won't regret it.
Den1
Yep i use the 9980 as well works a treat with Plusnet Tv  Wink
HairyMcbiker
Fixes: 21
Been using one on the TV service since it started.
Fuzzybee
Took the plunge and bought one of these, will be setting it up over the weekend, when people say to very easy to set up how easy do you mean. Any tips, I'll be setting it up via a wired connection for my plusnet tv, through home plugs for a PS3 then wireless for an Xbox One, various tablets and a couple of phones.
smokane
I have a router that has excellent qos settings and b/w control, but does not support IGMP
for anyone that has the tp link 9980 working with tv, it is possible to connect to the y'view box to a downstream router, or can it only connect directly to the tp link?
thanks
PeeGee
Provided that router supports IGMP as well, there should be no problem.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
smokane
Thanks for your help.
PeeGee
As an experiment, I connected the following "chain":
1. TP-Link TD-W9980
4. TP-Link WR1043ND (as a switch, no DHCP; note: WAN-LAN in bridge mode not tested)
5. Tenda G1008 (8w Gigabit switch)
6. D-Link DGS-1008D (8w Gigabit switch)
2 .TP-Link W3600 (SamKnows whitebox; WAN-LAN in bridge mode)
3. PN YouView+ G4 box
Items 4, 5 and 6 were added for the experiment. The Tenda blocks the IPTV and also blocks WoL messages, so has been replaced by the D-Link in my normal network. Removing the Tenda allowed full usage of the G4.
As mentioned here, the W9980 will also work with a suitable wireless node to connect the G4.
Phil
Edit: I did think of inserting the 2704n, but as it is configured in "toy mode", the dhcp messed things up Roll_eyes
smokane
That's an impressive collection of networking equipment!
Do you use this setup, or was it just for experimentation?
wisty
Fixes: 8
I use the following chain
1) Billion 8800NL Router
2) SamKnows Whitebox
3) TP-Link TL-SG108E ( 8W Gigabit smart switch)
4) TPlink Powerline Adapters
5) YouView box
The rest of the network (PC's, NAS box, printer, VOIP ATA etc) hang off the other ports of the switch.
When I got PlusTV, I had an unmanaged Netgear switch at 3)  that did not do IGMP snooping. The Billion does, but because the whole network hangs off a single port (so that it passes through the whitebox) it was passing all the multicast packets to the switch which broadcast them to the whole network.
Swapping to a cheap managed switch fixed that.
