Retuning youview box
jimhrvy
Is it possible to manually retune Plusnet's Youview box? I have the wrong HD channel for ITV, (I haven't checked further yet)? The box I have received is selecting the wrong area, harking back to earlier status quo for free view. Free view/Youview websites suggest doing a 'manual retune' to fix the problem.
1 REPLY 1
adamwalker
Fixes: 128
Re: Retuning youview box
It's not possible to manually retune but I would retune with the box with the aerial unplugged, plug it back in and retune again. Hopefully you should find that resolves the issue.
 Adam Walker
