Problem with YV Box
Mayfly
Seasoned Pro
Problem with YV Box
First my YV Box dropped the sound, I rebooted as per the instructions, then it was dropping the picture flashing grey for half a second every 2-3 seconds [no indication there was a drop on the internet connection via my PC. Now I can't get a picture on the TV at all unless I reboot the box.
With regards to the TV 'seeing' the YV Box does one need switching on before the other?
I've checked all the connections and they are OK.
2 REPLIES 2
Tibbie
Re: Problem with YV Box
Things to try
Is the problem only with IPTV channels or Freeview channels, either/or both
If its freeview remove the Ethernet plug from the back of the YV box does it still happen on freeview channels (My box had issues due to a faulty Cat5e cable!)
If IPTV channels cause the issue do you subscribe to the HD package if so is it happening across both SD and HD offerings
How is the ethernet fed to the box, straight bit of wire or by Powerline boxes,
try to eliminate as much as you can and reply back
Mayfly
Seasoned Pro
Thanks for your reply, although all the connections were fully home I changed the HDMI to a different socket on the TV and it all looks to be fine now - fingers crossed.
