Problem viewing paid channels recording!!
rkaur
i either get a lag before recorded programs from paid channels are played or get error 6024. is there a fix for this?
8 REPLIES 8
Chris
Legend
Fixes: 169
Re: Problem viewing paid channels recording!!
Do you have issues with recordings from non-paid channels or any of the apps (iPlayer etc)?
rkaur
no chris, just checked apps working fine and ive never had a issue with paid channels all fine. its just the recorded pay tv content which i struggle to access. sometimes it works but majority of the time a error message comes up IPC6024
adamwalker
Fixes: 128
Hi there, issues with paid channels can be caused by connection problems.
Is the box connected to the router directly or through something like powerline adapters?
 Adam Walker
rkaur
my box is connected directly though ethernet cable. all other internet features work on the box with no issue. just the paid recording ones which sometimes work but majority of the time its an error message i get
HarryB
Fixes: 255
Hi @rkaur, are you recordings failing before the programme starts or after the program has finished?
Do you also have problems when trying manual recordings as opposed to pre-scheduled recordings?
 Harry Beesley
 Plusnet Infrastructure Operations Professional
rkaur
hello my recordings just dont play, the playback on paid channels isnt working. i have the issue on scheduled and manual
Chris
Legend
Fixes: 169
The next step would be to get in touch with our TV support team either by phone or live chat, details of how to contact are available at www.plus.net/contactus
rkaur
okay i will do that. thanks
