Plusnet youview picture
Billk
Hi all, i have had youview from plusnet for over a year which up to last week has worked perfectly, some of the channels disappeared last week and had to do a retune to get them back, since then i have had a lot of pixellation and sound issues on the sd channels but the hd channels are working fine if i plug the aerial cable directly into the tv i have no problems on either sd or hd channels is this likely to be a problem with the box itself,
5 REPLIES 5
Fixes: 1,285
Re: Plusnet youview picture
Welcome to the forum Smiley
Just to be clear it's the over the air channels you're talking about and not the internet channels?
Billk
Yes it is the over the air pictures, internet channels are fine
OskarPapa
Fixes: 64
HI @Billk, thanks for your post.
We're sincerely sorry to hear of this issue and for our delayed response.
In the first instance, we'd recommend following the below instructions in order to reboot the box (granted, you may have already tried this):
1) Take the power lead out of the back of the box
2) Connect the power lead again, which will place the box into standby
3) Press the power button on either the box or the remote, which will wake the box up
If this doesn't help, we'd then look at entering maintenance mode and running a software reset. We can provide step by step instructions on how to do this, if needs be.
Let us know how you get on.
Billk
Hi Oskarpapa,
I have tried what you suggested and have also retuned channels several times but problem remains, if i watch these channels with the aerial direct into the tv the problem disappears which leads me to beleive the problem is with the you view box, thanks for your help
MatthewWheeler
Fixes: 405
Thanks for getting back to us @Bilik.
I'd recommend calling our TV faults team on 0800 013 2634 and then you'll need to choose option 2.
They'll be able to look at the possibility of getting an engineer out to investigate further
 Matthew Wheeler
