Plusnet youview+ box dropping audio only on network programmes
- TV
- Plusnet youview+ box dropping audio only on networ...
- « Previous
- 1
- 2
- Next »
Re: Plusnet youview+ box dropping audio only on network programmes
15-07-2019 10:42 AM
Hi @hedgie,
Thank you for providing your availability for an engineer, I've booked the next available appointment slot for you now. The date and time of this are account specific information so I've added the details to the ticket here. Please let us know if this needs rearranging.
Our faults team will contact you once we've received an update from our suppliers after the visit, but please feel free to get back in touch on here if there's anything that you'd like to discuss in the meantime.
15-07-2019 11:20 AM
15-07-2019 1:16 PM
Everything was disconnected, all connections unplugged at Master socket and it still showed a problem on the line.
15-07-2019 1:27 PM
@Shep41 wrote:
Has anyone at plusnet checked to see if your connected to a hot vlan?
Yes. As per the above there's a bridge tap on the line.
@hedgie wrote:Everything was disconnected, all connections unplugged at Master socket and it still showed a problem on the line.
Let us know how the engineer visit goes tomorrow.
16-07-2019 10:09 AM
BT Engineer has been and replaced Master socket. Said the problem was on the line but it should be ok now.
Can we rerun the test to see if the bridge TAP has been removed.
16-07-2019 12:05 PM
Hi @hedgie
Thanks for coming back to us with that update.
I've tested the line and everything is green across the board so I agree that the engineer appears to have sorted this.
Could you test your YouView playback and let us know how you get on?
Best wishes
Dave
- « Previous
- 1
- 2
- Next »
- TV
