Plusnet tv channels
Ki1
Plusnet tv channels
Hi Plusnet I can’t get my tv to work on hisense
3 REPLIES 3
mrmitch85
Re: Plusnet tv channels
You probably need to provide a little more information of the problem before anyone here is able to assist?
Ki1
I’m trying to find my channels and on my hisense and
I can’t find them
mrmitch85
I don't really think that's got anything to do with Plusnet then.
If you still have Plusnet TV, then it will be delivered via the Youview box, which will connect to your TV via an HDMI cable. (So you'll need to change the input source to HDMI).
If you're trying to find the channels on your Hisense TV then that will be the standard Freeview channels.
Ensure the aerial cord from the wall goes into your Plusnet provided Youview box, and that another aerial lead comes out of that box, and into the back of your TV set.
Also make sure the Youview box is switched on (so that the lights are showing blue) as it may not pass-through the Freeview signal if the box is asleep.
Then you can try scanning channels on your Hisense TV again.
