Plusnet fibre with Youview+ using Tplink vr900 router
poppy123
I have had fibre extra for a couple of years now and using the router Tplink Archer V900 with two homeplugs one for router and two others dotted around house both have twin Ethernet and wireless builtin. I just ordered today youview+ with HD extra. They told me on phone plusnet dont support this routers which is fair enough. They sending me the new router but rather use this one as I only just got it.
I cant find much to say whether it works with plusnet youview other than a review on amazon saying it does with latest firmware which i have.
Can anyone who has youview with plusnet and Vr900 confirm it works for me. Router does have IPTV is settings and has built in Vdsl modem. The router does support
Advanced Functions: Parental Control, Network Address Translation(NAT), Port Mapping(Grouping), Static Routing, RIP v1/v2(optional), DNS Relay, DDNS, IGMP V1/V2/V3
5 REPLIES 5
poppy123
Re: Plusnet fibre with Youview+ using Tplink vr900 router
Hello cant anyone answer my querier.
PeeGee
This post refers to the VR200, but may help as a pointer. Other TP=Link devices (eg TD-W9980) have everything set up as default. I would suggest plugging directly into the VR900 to set up the box as that confirms operation before using homeplugs.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
poppy123
Thanks I got the box found 148 channels freeview internet is connected I can play iplayer and netflix but no premium channels and so far 45 minutes on hold at plusnet
poppy123
I been talking with support we cant get it to work. the iptv settings when set wont allow the youview to work at all. The feault iptv is off it will connect to net and iplayer works
poppy123
now works thanks
