Plusnet always switches TV to widescreen
geoffrey1928
Really happy with all things Plus net....better service than BT and saving me over £25 a month.
One small little thing, when I switch on the Plusnet box, it always switches my TV to widescreen and I have to switch it back to full, otherwise much of the picture is missing, is there anything I can do to stop this happening?
6 REPLIES 6
picbits
Re: Plusnet always switches TV to widescreen
Are you using a SCART lead or HDMI ?
*Edit - if using a scart lead and you're feeling competent (or brave), disconnect pin 8 of the scart lead and see if that cures the issue - this is the widescreen / 4:3  switching pin.
jem16
Quote from: geoffrey1928
Do the settings allow you to choose picture format - ie widescreen or 4:3? If so what are they set at?
geoffrey1928
I am using hdmi, I can find no settings within Plusnet to set picture format
pwatson
Can you post a photo of your TV screen?  It sounds to me that the box is doing what it is supposed to!  You presumably have a widescreen TV as you have HDMI?
chenks76
Fixes: 12
the OP has his TV set to "full scan" (or the equivalent on that particular TV).
that is NOT the same as Widescreen, which actually cuts off parts of the image top/bottom/left/right.
"full scan" shows the complete image.
no box should overriding the image settings on a TV. if the plusnet box is doing this then it should be considered a bug/fault.
Chris
Legend
Fixes: 169
I've just been through the menus and the only settings I can see that might affect this, when plugged via HDMI, are the picture resolution and the zoom functionality. The picture resolution is in the settings menu, set this to match your TV. The zoom is controlled from the remote.
