Plusnet Youview Box
Cal24
Plusnet Youview Box
Does anyone from Plusnet know when Plusnet youview boxes get new software update
6 REPLIES 6
biggles001
Re: Plusnet Youview Box
Do we really need this update right now,the longer it takes the better,gives everybody time to get their act together
PeeGee
@Cal24  Is that because you want the new "touch screen" UI that cannot be used efficiently because you either cannot reach the TV screen or it does not have the required sensor panel or do you want to know for how much longer you will have a usable system?
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
jamesanstee
I got the new youview software update today does seem to be an improvement and appears to be a lot quicker.
Cal24
That for Plusnet box not BT one and what box do you have as I have Plusnet recordable
jamesanstee
Im using the plusnet box that was issued during phase 2 of the tv trials
Cal24
So my youview box from Plusnet drt t2120 won't get update for ages yet
