Plusnet TV with broadband
Interceptor121
Fixes: 5
I have (unfortunately) a broadband connection with speed of 13.5 mbps. This should be sufficient for standard definition TV that is around 2.5 mbps. For HD is likely to be insufficient
TalkTalk offer SD tv on broadband Plusnet and BT don't. Has this to do with multicast not available for broadband?
4 REPLIES 4
SteveA
Re: Plusnet TV with broadband
Unless things have changed the HD channel pack is a bolt on. I certainly don't have HD TV from PN - the Youview box however delivers HD Freeview channels from the aerial.
Interceptor121
Fixes: 5
Yes but my question is can I have just plusnet Tv plus kids add on without HD pack with broadband?
At present this is not available on plusnet but you can get similar packages with talk talk
SteveA
https://www.plus.net/tv/
shows Kids pack and HD packs as separate
so I'm not sure why you think you can't have Kids pack without HD
bobpullen
Fixes: 174
I think the question here is whether or not a multicast package can be taken with an ADSL service rather than VDSL, to which the answer is 'no'. It is technically possible, however it's not something we offer at present.
