Plusnet TV FAQ
Pete_uk
Re: Plusnet TV FAQ
Is there a problem today as I can't get any internet channels. I just get an error number 6015.
 I cant watch any recording either, so I guess internet channels don't actually record to the box?
Pete_uk
Re: Plusnet TV FAQ
OK, a quick box reboot and its fine. There is a error code site that gives you info on what to do depending on your error code.
Also, are recordings stored locally?
Re: Plusnet TV FAQ
Anything you record is stored on the hard drive built in to the box.
Pete_uk
Re: Plusnet TV FAQ
I just wondered because of the way it handles fast forwarding differently depending on whether it was recorded off the air or via the 'net
Re: Plusnet TV FAQ
You may be right. I only ever record stuff off air.
scirvine001
Re: Plusnet TV FAQ
yes, but you won't get the remote control with magic eye to work as it will only pass the picture down the cable
Superjackpot
Re: Plusnet TV FAQ
Hello!
So, I've just got an email about the BT sport App and pricing etc...but I was wondering if I take the TV package, can I cancel.it at anytime, or am I locked in for 12/18 months?
Many Thanks,
SW...
