Plusnet TV FAQ
- TV
- Plusnet TV FAQ
Re: Plusnet TV FAQ
07-05-2015 8:46 PM
Quote from: MattyC
Quote from: Mav I'm a bit confused. Are you really charging an extra £3 to get BBC1, BBC2, ITV1, C4 and a few others?
Just to clarify; all the freeview channels such as those come as standard with the box, making them inclusive of the £5 a month.
Matty,
Can you clarify if the full selection of freeview channels will become available to those who only get Freeview Lite due to being on a relay transmitter, or does the PlusNet TV pull them out of the air (where channels like Dave don't presently exist for us relay users) rather than over the fibre?
Re: Plusnet TV FAQ
07-05-2015 8:57 PM
Forum Moderator and Customer
Re: Plusnet TV FAQ
07-05-2015 9:52 PM
Re: Plusnet TV FAQ
08-05-2015 9:57 AM
Quote from: avatastic Matty,
As it stands, you should be able to get anything that this website advises. That is unfortunately your own transmitter so there is very little we can do in your case
Re: Plusnet TV FAQ
10-05-2015 7:00 PM
Re: Plusnet TV FAQ
10-05-2015 11:17 PM
Also is it avable to Fibre only subscribers?
Re: Plusnet TV FAQ
11-05-2015 6:30 AM
Re: Plusnet TV FAQ
12-05-2015 10:57 AM
Re: Plusnet TV FAQ
12-05-2015 11:39 AM
Re: Plusnet TV FAQ
12-05-2015 3:39 PM
Quote from: MattyC Best bet is to contact our Customer Options Team to discuss
Thanks for the reply - that sounds like a good idea!
Re: Plusnet TV FAQ
12-05-2015 6:09 PM
i) I use the RF Output from my Skybox to relay the signal to a different room so we can watch Sky there also. Is it possible to do this with the YouView box?
ii) I presume the Freeview will come via the existing TV aerial so does the HD come via the Broadband and as I will be stuck with a wireless or powerline connection, what if I can't view the HD without buffering? Is there a trial period if it doesn't work?
Re: Plusnet TV FAQ
12-05-2015 6:26 PM
ii) HD for BBC etc come from TV ae, the HD package comes from internet.
Re: Plusnet TV FAQ
12-05-2015 6:46 PM
The boxes do have SCART connectors so you could use a separate modulator if you wish eg
http://www.maplin.co.uk/p/programmable-universal-modulator-vh89w
Only the channels in the 400-600 range are delivered via the internet so if you can get the HD terrestrial channels now you'll be able to receive them via the Youview box (and record them if you get the Youview+ box) without paying any extra or being affected by internet speed.
Re: Plusnet TV FAQ
12-05-2015 6:46 PM
Quote from: Azzer31 ,what if I can't view the HD without buffering? Is there a trial period if it doesn't work?
As you have to have a fibre connection to get the service you wont have any problems with buffering for the HD internet channels. It works very well.
Re: Plusnet TV FAQ
12-05-2015 7:11 PM
